plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 8th, 2017, 02:23 PM   #1
dev67
United States
dev67 is offline
24V to 5V DC Buck Transformer on the same rail as inputs, is that bad?
I've had only rudimentary education in EE so I'm not sure about this setup. I've had 24V discreet I/O have problems in the past when a relay was added due to the inductive load screwing with signals.
Will this buck transformer give me similar issues if I have other 24 Volt DC components on the same rail? I assume it will act kind of like an inductive load while converting down to 5 volts DC but I'm really just guessing. I think it might just be power for photo eyes and proximity switches but I'm not positive. I'm looking to get some Pis in the mix and need a power source!
Here's the device in question.
Old December 8th, 2017, 02:42 PM   #2
jrwb4gbm
United States
jrwb4gbm is offline
1st of all, let me say I am just guessing here. The best answer I have is try it and see. Since the device is powered with DC in, I would think that there would be very little or no inductive load reflected back to the rail due to internal filtering of the DC/DC converter. Personally I would suggest using a separate 5 volt power supply connected ahead of the 24 volt rail supply source. That "should" isolate the two.
Old December 8th, 2017, 03:18 PM   #3
GaryS
United States
GaryS is offline
GaryS's Avatar
First there is no thing as a DC Buck transformer
Transformers work only with AC power the device you show is a DC to Dc converter.
I will convert either 12VDC or 24VDC to 5 VDC out
if you are having trouble with a 24v relay on an output the there are other problems
the relay will need the full 24VDC to turn on reducing it down to 5 v will not work to give you a better answer we will need more details
Old December 8th, 2017, 03:38 PM   #4
Mickey
United States
Mickey is offline
Mickey's Avatar
Unfortunately GaryS, that is what the vendor is calling it.
Quote:
KNACRO
KNACRO Waterproof Voltage Converter Regulator DC/DC DC 12V/24V (10-30v) Step-down to DC 5V 15A 75W Power Buck Transformer
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It is most likely constructed like..see link.
http://www.radio-electronics.com/inf...ter-basics.php
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old December 8th, 2017, 03:45 PM   #5
GaryS
United States
GaryS is offline
GaryS's Avatar
It's most likely a 3 point regulator with a power transistor output very common arrangement.
I would question the vender basis electric transformers only work with AC power
unless you are talking about the movie cars / robots but the even label the wrong they are automaton's
Venders should really get it right I find it all the time we know more then they do
But what is the actual problem I still don't have enough information
Old December 8th, 2017, 04:08 PM   #6
dev67
United States
dev67 is offline
No outright problem yet, I was just asking to see if there was an obvious mistake in my logic for placing a 24V to 5V DC converter on the same rail as a bunch of photoeyes and proxes. When I had a 24V relay hooked up in a similar situation in the past, the inductive load screwed up my discreet signaling. I just wanted to be sure there wasn't an obvious problem with having this converter on the same level as my PE and PXs. jrwb4gbm mentioned that he thinks the converter should have some filtering to keep any electrical back noise out of my 24V rail, but yea as a rule of thumb it'd probably be better to have a 120AC to 5V on a separate rail entirely. I'll probably try it out from the 24V first but with some attention to my 24V I/O just in case. The fact that this vendor mislabeled the product on amazon doesn't instill much confidence.
Old December 8th, 2017, 04:22 PM   #7
GaryS
United States
GaryS is offline
GaryS's Avatar
I would go with the separate 5 volt power supply it will give you less problems
I have put relays on the same rails ad I/O and never had any problems
I think there is something else going on there if a simple relay can cause that kind of problem then motors will be a real big problem. I would be looking at other things.
Old December 8th, 2017, 10:21 PM   #8
keithkyll
United States
keithkyll is offline
You should not be using automotive products for industrial control. It expects a battery input. Doubt if it has anything to prevent noise on the input line.
75 Watts for 15 bucks is scary just by itself.
Use an industrial type. Here's one that's close from Automation Direct.
The issue you had in the past with a relay was probably because someone forgot to add a snubber (AKA Flyback) diode. See this recent thread for more info.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Water meter & PLC hashem LIVE PLC Questions And Answers 14 April 29th, 2013 11:56 PM
Allen Bradley Basic Card XEV2005 LIVE PLC Questions And Answers 19 March 22nd, 2012 02:28 PM
Problems with PF700S inputs milldrone LIVE PLC Questions And Answers 7 December 12th, 2011 07:48 PM
S7 300 SM331 Analog Inputs Problem; Relative DC leval of adjacent inputs. David Torrens LIVE PLC Questions And Answers 4 November 10th, 2004 10:14 AM
5V Inputs gbradley LIVE PLC Questions And Answers 6 February 26th, 2003 08:17 AM
