Hello
I have an AB micrologix 500 plc 24vdc. Its powered from a seperate 24v PSU. Im trying to wire up the outputs to this and would like to ask for some help to do so to avoid blowing the thing up
The output terminals are mareked as follows.
VAC/DC, O/0, VAC/DC, 0/1, 24VDC+, O/2, O/3, 24VDC-.
In that order.
Am I correct to assmuse that you plug 24vdc+ into the 24vdc+ terminal from straight the power supply. And 24vdc- into the 24vdc- terminal straight from the power supply. Doing it like this what does it make the polarity of O/2 and O/3?
Also with the VAC/DC terminals can i just plug 24vdc+ into them and get 24vdc- from 0/0? and 0/1?
Hope this makes sense to someone any help would be much appreciated Thank you for taking the time to read my question
In that order.
