Panelview Standard doesn't retain application
kbupnorth
Apr 2013
MN
I had to replace a Panelview Standard 1000[2711-K10C3L1] with a refurbished model as the standards are obsolete.
I can download and run the file, but if I power the unit down and restart, I get a white screen that states there is an application error and goes to the configuration screen. It seems it is not retaining the application and other configuration settings. I didn't see a battery on the board, thinking it may need one. Has anybody had this problem or am I just missing the obvious?
Thanks!
per the RA KB 14826
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/14826
PanelView Standard terminals contain a real time clock module. That module contains a battery in a socket for the real time clock and static ram for parameters and configuration information
Perhaps you can swap out this module with the one from your original PV1000
Also, you did not state the firmware version of the refurbished model.
You could try to update the firmware to the latest version supported for that model.
Had an interesting experience this morning. An old Panelview 600, 2711-K6C5X series B to be precise, comes up as error 32. Unfortunately it...
207
Good evening. I am in serious need of help. I am trying to connect a Panelview Plus 7 Standard to a SLC5/03(1741-L531) using a Moxa MGate...
636
Good evening. I am trying to get a SLC 5/03 connected to a Panelview Plus 7 Standard using a Moxa Mgate EIP3170 and I am not having much luck. I...
519
Hello, We have an older machine that has a standard PanelView (2711-T10C3) connected over DH485 to a SLC 5/04 PLC via a 1761-NET-AIC module in...
671
Hello All. I have an interesting one for you. I have a brand new Panelview 600 Standard 2711-K6C20 and I'd like to get it to talk to an L81E...
2,011
