Micro 820 fault code
speaksy87
May 2014
PA
I have a micro 800 that keeps going into fault mode. The fault code is 0xF000
The controller was unexpectedly reset due to a noisy environment or an internal hardware failure.
If system variable_SYSVA_USER_DATA_LOST is set, the controller was able to recover the user program.
but the user data is cleared. If not, the Micro800 Controller program is cleared.
Does this mean that if the Data-Lost variable is not set the controller deletes current program?
What could be causing this fault code to be reoccurring?
There is several post concerning this Fault with the Micro820 on this forum, you should read them!
I too have encountered this error on more than 1 occassion, and have found it to be associated with 2 things - atleast for me.
1. I use an RTO offen and I found one of my variable was set incorrectly(However - I was also using an older "Firmware"!
2. So it seems that (Re-flashing or updating) the firmware solved all of my problems.
So you can try just re-flashing if you are at current firmware(10.01) or update to the latest(10.01).
Keep us posted.
I’m running a micro 820 to measure a tank level, then turning on equipment at certain levels. I have an analog input (4-20) that I’m storing and...
302
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
377
The micro 820 is visible in RS Who when I configure my Ethernet to capture the random IP. I am getting an error when following the steps below...
1,010
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
491
