Beijer 1071
Benyamin
Mar 2012
Dallas
67
Hello,
Can somebody tell me how to backup/transfer program from Beijer 1071 Panel Operator/HMI to a CF Card and vise versa?
Thank you.
Benyamin
Perhaps you should post this into the main Q&A, anyway if I remember correctly to back up you really need E-Designer, however, there is a way. power down the HMI, select dip switch 1 to on (I think) then re-boot, it will come up with a screen allowing upload/download from memory card. The card needs to be configured with directories & must be FAT32. I have never uploaded only downloaded so don't know if you can, the file will be a dat file so cannot be edited. the best way (assuming no password) is to use E-designer to upload the project then you can export it to a DAT file & put it onto a flash or USB card.
If I remember correctly, if you plug a clean card into the HMI & wait for a while it will configure the directories for you.
Having tested it on a spare HMI, you can only download a saved project from a usb or card.
You can't upload the project without the E Designer software.
The help on E designer is not very good although it implies you can. However, I have just loaded a project & set up a function key and there is a function to upload application to USB, so it can be done if programmed in a function key, however as I do not have a spare HMI I cannot try to upload to USB from the program transfer screen when booted up with Dip switch 1 on, I know you can transfer from USB this way but not checked if you can transfer to USB. When I get a chance I will try it (spare HMI available that is).
Hello, Can somebody tell me how to Upload and Download program from Beijer 1071 Panel Operator/HMI to a CF Card directly without E-Designer, since...
1,469
Hi! I have a E1071 from Beijer in use since 14 days. But now it does not start the project anymore. When i turn on the E1071, it writes: Status...
3,434
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
104
Hi all, First post here, I hope I'm putting it in the right spot! I have an ancient Beijer E910T which went down today. Given the proximity to...
313
I am looking to upgrade a CompactLogix on V18 to an L83E on V32 which is currently using a Beijer E1151. Does anyone know if the E1151 is directly...
656
