Problem converting number from string text to integer
jendrus
Nov 2011
Midwest
21
Hello folks,
Using AB RSLogix micro..
I have a 6 digit ASCII text string and Im looking to convert the 4 most significant digits to an integer using the ACI instruction, problem is that I get overflow errors because sometimes the conversion exceeds the 32767 limit..anyone have any idea how to extract the leftmost characters of the string so that I can then convert to integer
Thanks for your help
Hello, I've got a problem when converting my old PanelBuilder aplication to the new FTView ME plataform due to the need of replacing my PanelView...
2,292
It's been a while that I can't convert one of my program on concept using concept converter. When I try converting it, it pops an error (ERROR...
1,208
hi all i have problems when i try to convert s5 program to s7 the problem is db0 this is the code that contain the error Segment 3 of 8 :JU...
1,853
Hello, I am inquiring if anyone else has had this issue, I have talked with rockwell tech connect and even they have been unable to resolve yet...
2,010
i have a program at work on a very large line. i was trying to change a value of a constant number.( emov E10 d5282 ). there are many rungs of...
1,915
