Shiro485
Hello,
I am inquiring if anyone else has had this issue,
I have talked with rockwell tech connect and even they have been unable to resolve yet.
I have an old panelbuilder application that needs to be converted to panelview plus. The communications used to be dh485 will now need it to be df1 from plc to hmi
Using a slc 5/03 processor. pvp 600
When importing the application into ftview studio it tells me the slc_1 node for dh-485 is not a valid node and turns all my tags into memory tags instead of retaining their plc addresses.
If i change the tags in the tag database to device instead of memory they all have the address of b3:3/11.
I have tried conversion on both 32 bit and 64 bit machines.
Rockwell tried converting my program with same result.
I am using ftview studio 7.0
Can anyone help?
Thank you
Can anyone help?
Thank you
