mistibishi converting problem
jolley2051
Jan 2013
alabama
i have a program at work on a very large line. i was trying to change a value of a constant number.( emov E10 d5282 ).
there are many rungs of logic in this program that are the same type moves. if i try to change anything in this rung and then go to convert it says "program before correction differs from the registered program" i can however change other constants in other rungs and convert it fine. i have verified with plc, read from plc, and wrote to plc, but still same problem. any ideas. and does anyone know what is ment by registered program?;)
THESE ARE JUST CONSTANT MOVES TO BE USED AS OFFSETS TO ADJUST TEMPSONIC RODS, ENCODERS, AND LASER SENSERS.
welcome to the site
please let us know which PLC CPU you are using.
Also is there an EEPROM as this may be the problem
hi Ian
it is a Q06UDHCPU
Im sorry but im not really sure about the EEPROM. to be honest im not even sure what that is unless you talking about a memory chip.
sorry to say my skill level is med. at best.
i am a multicraft maintenance tech and not an expert on anything
What are you using for software? GX Works 2 or GX Developer?
Are you trying to to do an on line conversion or are you converting and writing while off line?
Dave
thanks dploof23
your offline comment made me start thinking.
what i had to do is
go to write mode and make my changes. ( i was doing it in monitor write mode). then write to plc.
now i can go into the monitor write mode and make my changes.
learning experience!!!
what I am reffering to is - does it have a memory flash card - you may alter the PLC program but as soon as you power down the flash card program is reloaded to the processor.
this may not be the problem but just a thought
Hi, I have recently been making some online program changes to a Q00UCPU plc. I have been using a USB to USB-B connector. And have been happily...
748
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
213
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
127
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
335
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
395
