VMware Workstation Player - Moving virtual machines.
Elcan
Apr 2008
NC
935
Hi all,
I want to move a virtual machine from computer A to computer B. I've done this several times in the past.
I used to get the "Moved it o Copied it" question in the past, but I am not getting it now. Also, Windows is not activated on the virtual machine on computer B, but it was on the virtual machine on computer A.
What am I doing wrong?
Thank you!
I moved a VM using VMware 12.5.9 last week and got the "Moved it or Copied it" question. I think Windows was already activated on it too. So I'm not sure why you're having this problem. Which version of VMware are you using? Did you install a new version/upgrade/install any software updates recently?
I managed to make the "Moved it or Copied it" show up again. I selected "Moved it".
Now the problem is that the guest OS (Windows 7) claims that I have 3 days to activate it, when on the original host it was already activated. First time this happens to me.
Has anybody experienced this before?
Once, I bought a license off eBay for around £2, delivered in 1 minute, it worked, was no drama.
Effective approach, but you need to buy a license every time you move your virtual machine. The "Moved it" option was not thought that way.
After a few tests, I found out that some VMs could be moved without altering the guest Windows activation, some not. I didn't have the time to look for a pattern, though.
Hi guys, I am trying to use VMware workstation 16 player to configure RSlinx but have run in to all sorts of issues. 1. Not able to configure...
2,550
Hi. Currently I am at work using VMware Workstation 10, with great success. Now, for my private use, I am thinking about using Virtual Box or...
3,836
With the advent of Windows 7, i think i am looking into VMWare to run windows XP and older Rockewell Software. I am unsure as to what the major...
26
19,988
Hello Everyone, I know there are a couple of threads on VMWare and Rockwell, and it has been discussed before, but I was hoping someone could...
1,869
I'm currently trying to setup a VMWare Workstation VM for Rockwell PLC's I would like to have RSLogix 5 v10, RSLogix 500 v12, RSLogix 5000...
3,382
