I'm a C++ programmer and I'm assigned to make an application that periodically shall comparer the online software vs the offline on a Beckhoff TwinCat system. Then intentition is that we should notify the customer that somebody has changed the online sw, meaning the online sofware is not the same as offline.
We have a working solution for Siemens PLC's where we calculate a checksum for the online and offline software and compare these.
So for the Beckhoff TwinCat system I need either a tool or a library(hopefully C++) that can do the same, or better do a direct compare.
