Controllogix and Modbus TCP server AND client, MARINE APPROVED
Kicken
Mar 2012
Vaasa
Do you guys know of any marine (ABS or DNV) approved modbus TCP solution for Rockwell Controllogix?
Our system:
Redundant 1756-L72
- Act as master(client) connected to 6 Modbus TCP slaves(servers)
- Act as Modbus TCP slave(server) (redundant=needs to be separate ports)
Erlier we have used Prosoft cards, but those don't have valid marine approvals anymore.
Rockwell own software code for Modbus only supports 4 slave, and slave and master is not officially supported at same time?
Ask Red Lion if they have received ABS certification for the standalone Graphite Edge controller. I know they got ABS for some of the related Graphite touchscreen HMIs.
I see where you're looking at the DNV certificate for Prosoft's MVI56E; it was renewed in 2016 and that expired just a year later in December 2017.
Be sure you ask Prosoft directly if there is a newer document than the one which is online. Sometimes website maintenance and updates lag behind the real world.
Hello all, I was wondering if you clever people could help me, please. In the past I have used a standalone L33ER CompactLogix PLC with the...
1,525
I am working on a project, inside an AB CLX, I implemented the Modbus TCP Client AOI published on AB website, to interreact with a Modbus ASCII...
3,559
I am not very experienced in Rockwell PLCs and have run into a small problem, so I could do with a little bit of help. We have a redundant...
2,530
Hello All, I'm looking for the Coles notes on how to inferface a Modbus TCP device (compressor controller) with a Logix 1756 L72 running V24...
5,889
Hi all, I'm working on a wastewater plant where I have a ControlLogix PLC as the master PLC, alongside three packaged systems that are being...
3,863
