rexroth amplifier cards
Do you mean a VT 5004 or a VT 5014. I don't know about a VT5041 (but that doesn't mean it doesn't exist.
Let me know. If I can't help this weekend I can certainly help Monday when I'm back at work (we're a RR distributor).
Dear Euipfacil,
I have a lot of experience in adj VT 5041 on injection moulding machine. Please confirm which type of machine is install on this card. which machine size, whhich model and which software version is install on this machine.
I now have this issue done. The downloads that were posted helped me to get this issue behind me. As for the machine it is an old B56 Rep machine that I coverted from the propriatary Rep controller to AB. I had some issues up front with Hydraulics...cards, scalling, and various other small issues but as for now machine works well! Thanks again for all of the helpful posts.
LR
Rexroth VT 5041 question
Looking for information on the type of meter used in this controller. The scale is labeled for +/-, presumably current.
If anyone has a clue, or perhaps one for sale, please advise.
Kind thanks,
Irving Wiener đź“š
If you are talking about the meter built into the face of the card, then this generally shows the actual angle of the swashplate in the pump and so it corresponds to the flow coming out of the pump.
More on the VT 5041
Kind thanks for your reply. However, I need some info to replace the meter. Any idea of what type of meter it may be?
Thanks.
We have procured on rexroth valve 4 WRZE 16W6-150-70/6EG 24ETK 31/A1 D3M, I want to which rexroth card will support this valve & can be interfaced...
4,035
Apparently there are a lot of these systems still running the field today so I thought perhaps this information might be helpful to someone in...
91
Hello, what program is it used to connect with laptop a rexroth indradrive HDS02.2-W040N-H(verry old model), i'm guessing because its old so on a...
1,303
Has anyone put together a combination of the Beijer iX Developer software and a Rexroth L54 controller over ethernet? Can't seem to get the...
550
Hi All! I have a project where communication needed between an Allen Bradley CLX and a Rexroth CML25. Do anybody have experience with it? We...
783
