factory talk view ME removeal
blaster_works
Jun 2015
wa
So here is my issue.
i have been using ft view ME for years.
to make a long story short was running version 11 tried to load version 12 but it is a windows 7 machine.... no matter what i do i can get version 12 completly off of the machine. it looks like it is off deleted from programs and features along with anything that relates to it.
Also i am working with rockwell tech support at this point.. they gave me a list of items to delete including registry entries. It is still a problem.
when i go to load 11 , it is yellow with a warning saying version 12 is still loaded.
thanks for any pointers
Sounds like you are in a bad spot here. FactoryTalk downgrades never go well. Especially when you get to the point of manually deleting directories and registry entries. It is quite possible that you are going to put signifigantly more effort into fixing your machine than you would if you just reinstalled Windows, or better yet, install a virtual machine and do a fresh install of FactoryTalk.
  • First law of FactoryTalk, never downgrade
  • Second law of FactoryTalk, always use a VM
Edit: Welcome to the forum.
well back on the line to ab support
moving up the food chain.
getting a new machine for a fresh load but in the meantime trying to get this one operational. I do alot of other things on this machine.. really cant afford the downtime...
thanks for the feedback.
Yeah sorry it wasn't very helpful. Would the VM be an option for you?
Windows 7 creates "Restore Points" before you install or remove a program. You should be able to restore to a time before you installed v12.
OG
91
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
322
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
289
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
593
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
369
