PanelView 600 IP
Mark_005
Jan 2019
Mexico
Hi!, I need a answer for a problem that I can't find the solution, I work with two filter press, the control is by the panel mentioned, one of this is damaged, the damage is in the touch panel only. I bought a new one with the control installed on the HMI but I can't stablish the communication with the HMI and the PLC, the communitacion it's by ethernet and I tried different IP's the provider game me but none of this works, I thought in possible solution: find a way to get the IP adress of the damaged HMI, I tested the HMI communicating with a PC and it receives a response from the HMI, the only thing that I don't know is the IP, there is a way to find the IP in the damage HMI?
In most cases, the IP address with be set to static in PLC and HMI hardware. Do you know the IP address of the PLC? Can you give us the complete catalog number of your Panelview?
I am trying to go to a 504 CPU. and on my hmi I am getting a 9028 error. can someone explain what they mean by change reference?
220
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
462
Hello, Friends Please someone help me find right cable to communicate Panelview 600 (2711-B6C9) to Micrologix 1200 (1762-L24AWAR). AND any advice.
271
Hello , I have an HMI of PV+ 600 (2711-T6M5D) Ser A Rev B, This HMI doesn't have the ethernet port i have to take backup through communicate...
653
Hello all, I copied the MER file from one PanelView Plus 600 to another one, using a USB drive. On the new HMI, I copied the MER file to the...
628
