Can PowerFlex 4 Parameters be Backed Up During Operation?
MoraleC2
Jan 2016
East Coast
23
I have a client that wants software backups of all drive parameters, so I am going to connect via CCW. Obviously, they would prefer to not stop the machine while I do this, so I am wondering if connecting to the drive will cause any problems while it is running?
They also have some old Hitachi L100 drives, to which I will be connecting with Pro-drive, and I am wondering the same thing about them.
I know that you can with the powerflex drives, I am not sure about the others.
You can definitely upload / "read" all of the parameters of any PowerFlex drive during operation.
Some parameters won't allow writing during Run mode, or won't take effect until after a power cycle. But upload... all day, no problem.
As far as I know you can use a 1203-USB it comes with 2 leads one to connect to PF7 series and one to connect to PF4 series, PF523 and PF525 drives.
As long as you are not using the DSI port you can connect to any PF4 series, PF523 and PF525 drives. Not PF527 which has 2 ethernet ports and the configuration is done in ControlLogix.
PowerFlex 4 drives have a DSI serial port, same as PowerFlex 40 and 400. It's physically RS-485 but the Drive Serial Interface (DSI) protocol is a superset of Modbus RTU. It's an RJ45 jack because RA was torn between "people are going to mistake it for Ethernet" and "not another novel connector !".
The direct interface is a 1203-USB, the successor to the old 1203-SSS "snake head" interface, which supports DSI, DPI, and SCANPort.
More commonly the drives are connected one at a time, or in groups, to a network adapter like a 22-COMM-E mounted on a larger drive, or a standalone 22-XCOMM-DC.
I wish RA had built a cheaper USB/DSI (only) interface, but the argument is now "that's moot there's USB direct on the 520 series", and "Ken shut up, DeviceNet died with grunge".
Looking for some assistance. I am very familiar with Yaskawa VFDs, but not so much with AB VFDs. I am working on some hardwired AB PowerFlex 700...
127
Hello, I am playing around with a Powerflex 525, I am able to run the drive via RSlogix 5000 over ethernet. I am curious on how to set drive...
609
Hello Everyone, I have multiple machines that do the same thing, only the IP's are different. Some of the machines have AB drives while others...
16
1,224
Howdy, very happy to have found this forum. I purchased a piece of equipment (canning line) that has an old PF 40 drive. It ran fine for a...
1,175
Good Morning, I have a powerflex 70 drive with an RIO card for communications and had a quick question. I am having trouble with the parameters...
1,675
