Trying to Download a RS Logix 5000 program to a 1756-L62-Following Errors
Cydog
Feb 2018
Maryland
313
Good Morning ,
I received a used 1756-L62 / A CPU , from a vendor that was using it for a trainer. I tried to download a program that is being used on the plant floor that is using a 1756-L62 / B . I get the following errors when I try to download.......
Creating all 'Batching_Station_1' Tags...
Creating all 'Batching_Station_10' Tags...
Error: Reply buffer invalid.
Error: Failed to create Programs and Add-On Instructions.
Complete - 2 error(s), 4 warning(s)
The program has a number of Add-On's , and using ControlNet . Do you need to load anything separately , such as the Add-On's , etc. What would these errors mean ?
Thanks as always for your help,
I don't remember differences by heart, if you go into the tech documentation and the release notes of the firmware, if there is anything, it will be there.
Are you sure, you have the same firmware revision on your application and the controller?
Are you using a 1756-ENBT by chance? If so take a look at Tech Note 61910.
The solution from the Tech Note is to replace the 1756-ENBT module.
I am trying to use the upload download tool but when I hit the browse tags button on step 5 I get "Error 380 Invalid Property Value". It does not...
14,656
Have a Micrologix 1500. Trying to download to a Panelview 300 (2711-K3A5L1) using a 1761-CBL-PM02. Is this possible?
2,359
Hello! When trying to load the hardware configuration I get error 0050-133 2 2458, check the diagnostic buffer. When checking the buffer, it says...
228
Hi, New to the forum. I have an old machine I am working on that is using aA172SHCPUN. I want to capture the program in case I need to reload...
22
2,122
Hi guys! I'm trying to download a project to the controller, who already has an aplication running protected by a blank password. The option to...
2,964
