Prince
- Join Date
- Jun 2002
- Posts
- 284
During a project for a roller table I am using some proximity switches between the different rolls in order to start the rolls on time and monitoring. Roller table is used to deliver the manufactured 6-12 meter pipes to their testing station. Mechanics advised me to use the below shown method to fix my sensors among the stands and protect them from being harmed by the crossing pipe (sorry I am very week in drawing )
At first I recognized that I do not have a permanent signal from my sensors, pipe jumps up the rollers some time I accepted that and made the program not mentioning the signal cut for short times . but the problem gets worse now . Some of the wrong pipes break the whole steel made holder off (thanks god sensors are happy in their cage).
We must change them it was a fact. Photo electrics are not a good substitute they are sensitive to any moving thing even the laborers moving among the stands they will ruin the sequence. Bigger proximity sensors (e.g. 12mm) are rather big to be placed and of course not economical at all . I am not sure if a 40 mm sensor can stay far enough from the dangerous pipe crossing. We are not very keen on limit switches as we are not prepared enough to build new holders and rough placing plots for them.
We are clueless about the problem. We thought about a flexible or spring leg for our holder in order to avoid break we are working on that but I thought one of the professionals might have a relative experience and solution.
P.S : Sorry for my English
