Registry from ControlLogix to Excel using Visual Basic Application in Factory Talk SE
Jun 2016
Venezuela
29
Hello there, world!
The problem i'm facing up is about a registry I need to do in order to compare the set point versus the real variable I got.
From FactoryTalk Site Edition I was able to create a button and link it to VBA (Visual Basic Application) so everytime I pressed that button the registry is made.
The thing is, I need that registry to be made automatically. For example when a tag in my controller is change from 0 to 1.
I'm running into a problem when trying to use the RSLinx Backup Restore Utility where it throws an error when it tries to restore a backup. The...
564
Hello I was needing some help to writing a batch file that will add a value of "1" into a Windows "String Value" Registry key. The registry...
2,171
Hi I Hope someone can help me with this, please I want to automate a weigh bin filler(for fruit) but I 'd like to store in the HMI the total...
2,339
Hello, I have one computer where the trends fail to create a history log. The first time you open a trend ( on project load ) it says "failed to...
1,946
I am trying to write a panel script to reset a registry file in the plc at a set time of day. I am not sure what script functions to use
1,400
