1747-uic gets automatically disconnected on win10
Mar 2019
Bokaro Steel City
I connect SLC 500- 5/02 cpu with 1747 UIC card to my Win10 pc using rslogix500/rslinx classic.
There are four CPUs in a series.. if I leave the PC switched on in a network, I find all the nodes out after 24hrs. All the nodes are back when I restart my pc.
Why does all the nodes get disconnected. How can I make them connect with REFRESH/AUTOBROWSE rather than RESTART.
Is your PC going to sleep? most PC's will disable the USB port when this happens... if the port get disabled you will need to Stop the driver in RSLinx and restart it then they will start communicating again
Try looking at your PC "Power Plan" in your control panel
I don't have Windows 10 so hopefully this is the same:
- Open Device Manager
- Expand Universal Serial Bus controllers
- Open the properties of each item under it
- Look for the power management tab (not all have it)
- Make sure "Allow the computer to turn off this device to save power" is unchecked.
The way I did it on W10
1 Type 'power management' in lower left comand
2 Click on 'Addition Power Settings"
3 Click 'Change Plan Settings'
4 Click 'Change advanced power settings'
5 Click the + sign on USB
se me desprendieron los cables del cable usb quiero soldarlos pero no se como van los cables si alquien me pudiera proporcionar una foto o como...
401
Hi again, so this new client has a SLC 5/02 with a DH485 port. I have the older white 1747-UIC adaptor, which I have only ever used for the RS232...
1,294
Hi Everybody! Has anybody ever tried using the 1747-UIC (USB to DH-485) converter as a straight USB to RS-485 converter? Since it present to the...
2,425
Hello I will make it short and sweet. I need the cable that goes from the slc 501 to the 1747-UIC RJ-45 connection. From what I can find it...
1,248
Hey all, first time posting. I have gotten a lot of great info from all of you in the past. I have searched the forums and google as much as...
3,454
