iansabey
Hello,
I have a Step7 5.5 project with a large number of profinet devices which will be activated/deactivated from time to time. I can use SFC12 to do the (de)activation but if the PLC restarts, all devices are activated. As there are more to deactivate than activate it would be best if they were deactivated by default. In the hardware config there is a column "Initial State" which is "Activated" for all devices. Is there a way of changing this so that some have an initial state of Deactivated?
Many thanks
Ian
Many thanks
Ian
