IDEC MicroSmart Pentra FC5A-C24R2 RXD/TXD through RS-232C
vislab
Feb 2005
20
Hello everyone,
This time I have IDEC MicroSmart Pentra FC5A-C24R2 and using WindLDR v5.01 software for programming.
This PLC is connected to the COM1 port of the desktop PC and I would like to send or get simply now "OK" characters between PC and PLC.
I used Visual Basic 6 to make a simple application running in PC to send or receive this simple signal through serial RS232C COM port.
Now I used RXD/TXD instruction in the PLC to send or receive this simple "OK" signal but it would not work.
I download this very simple code and run it in Online Monitor mode but I saw nothing happened.
The login is like this if the input I0 is ON then it activates the M101 and this will go through SOTU and activate TXD so that in the PC the VB application receive the "OK" and display this in the text box.
I attach this logic as following for your reference but it should be easy and straight I don't know why I have problem.
Then I apprecitae your any help and recommendation.
Thanks and see you.
Sonny
Hello everyone,
Thanks and see you.
Sonny
know this is an old post but did you get it to work?
Could anyone share the pinout of cable connect between PC and PLC IDEC Microsmart Pentra FC4A-KC4CA Serial programming cable for FC4A and FC5A...
5,438
Greetings to All I have IDEC microsmart FC4A - c24r2 PLC... I need to format the old program in that... it was password protected. How do I...
1,586
I am currently using Direct logic PLCs and C-More touch panels and was approached by an IDEC rep. Does anyone have any experience with both of...
1,747
I saw a blurb somewhere one time that Idec MicroSmart series PLRs were rebranded Twido's (or the opposite). I have never used the Idec series, but...
2,607
I'm trying to program an IDEC Microsmart series PLC. The WindLDR program does not have a built in retentive timer. I am trying to create a cook...
2,735
