CENTER
Had a call from a customer that had a simple logic problem with a machine today that turned into a devicenet problem. I can't get there for a few days, so I was working with them over the phone and it sounds strange and does not make a lot of sense. They have a SLC with a devicenet card in the rack.
They have a Buss out fault 91. Had them check the voltage 24VDC on all devices Checked the resistance on the can wires 60 ohms. Everything looks good. Unplugged all the drives the encoder and the HMI come up ( they are on the end of the line ) plugged in Node 10 all good 11 12 13 any one of them cause the fault. Any idears would be appreciated.
Node 10 to 13 are AC drives 14 is a HMI 15 is an encoder.
