Inductive Proximity Sensor with a One-Shot Output?...
Eric Nelson
Apr 2002
Randolph, NJ
4,346
I'm using an Automation Direct SureServo drive, and it has an 'odd' homing routine. Depending on the state of the home sensor when the HOME routine is started, it ends up at 2 different final locations. See MY POST at the A-D forum for details.
I think the simplest 'workaround' would be if the home sensor could generate a one-shot pulse when it turns ON. This way, the servo drive would always home to the same location. I was wondering if anyone knew of an inductive sensor with this logic built-in. I'm currently using a 12mm tubular sensor, but any size or shape would probably work. I know I could just use a timer with a one-shot or 'pulse' output, or a dedicated one-shot module, but this panel is pretty cramped, so I'd rather not add additional components. If I could simply replace the sensor, that would be ideal... :cool:
-Eric
with one or more relays you could prevent the homing command unless the Prox is off.
If needed, then allow the homing in the FWD only or hold it on when the Switch is made.
the logic and relays can both be small.
At the worst case - use a smart relay.
I agree Ian on his point here.
Or, another way to take care of this problem, is use the control system (plc if is connected to)that's controlling the Servo drive to handle this issue. All you need is 2 I/O (the prox and the output)
Perfect solution! I knew there MUST be something out there. These might come in handy for other applications too. Thanks, controlled!... (y)
As far as the other suggestions... I can probably accomplish this with just one additional relay. The home sensor is wired directly to the servo drive, but the HOME command comes from the PLC. I can probably just wire the home sensor through the NC contacts of a relay. When I issue the HOME command (or slightly before), I can turn on this relay for a short period of time. If the home sensor happens to be on, it will be ignored long enough to move off the sensor.
My only concern with Plcwill's idea is signal delay. I/O response time and scan time may affect repeatability. In this application, I'm homing at a slow speed, so it probably isn't an issue. If you read my post at A-D's forum, you'll see that I was originally using the index mark on the encoder for home. This was extremely accurate.... until they changed gearbox ratios on me... :rolleyes:
Thanks guys!... :site:
-Eric
Oops! Wait a minute... Those Balluff signal conditioners can only be setup as an on or off-delay timer. I would need a one-shot (sometimes called 'pulse') output... :(
A good find regardless! I can think of a few other applications where they will be helpful.
Oh well... I guess I'm back to adding a relay.
-Eric
EDIT: I see you're paying attention, Bob!... :D
Thanks, Bob. I stumbled across those during my initial search (Looks a lot like a Keyence photoelectric amplifier!) They would work but, as you said, they're probably beyond this project's budget. A cheap relay and a spare PLC output will be more cost effective... :ROFLMAO:
-Eric
We have an old piece of equipment with 5vdc control power. One of the components is a 3-wire NPN shielded 12mm cylindrical inductive prox. I have...
2,954
Hello All, I have a seemingly simple question. I have a Turck AC powered inductive proximity sensor. The load has to be connected in series with...
8,717
Hi everybody I use Telemecanique XS1M30MA230 inductive proximity switch in one of my application. It is attached to a moving body. It is working...
5,451
Hello All; I am wondering if anyone has ever come across an inductive prox (preferably cylindrical style) where the sensing face lights up to...
2,121
Dear All, I am using PNP 3-wire DC 24V Inductive Proximity switch and now I need 2-wire DC 24V Inductive Proximity switch. I doubt whether it...
7,271
