2-wire DC 24V Inductive Proximity switch??
drspanda
Oct 2005
Damanjodi
155
Dear All,
I am using PNP 3-wire DC 24V Inductive Proximity switch and now I need 2-wire DC 24V Inductive Proximity switch. I doubt whether it will be available or not.
My PLC is AB with sinking input type...I mean positive 24V goes to the field and comes back to Input card.
I may be helped.
drspanda said:
Dear All,
I may be helped.
Heads up alert!
Your 2 wires will leak and your PLC input will always be energised... unless you add a load to common between the IO and the device.
Pierre said:
Heads up alert!
Correct. Man this gave me headaches one day. Use a interface relay or something
Heads up alert!
I am having this problem now. I have a prox switch going to a wago IO system. Blue wire connected to 24v common brown wire connected to 24v input card. trigger the prox and red light turns on and i get a 1. pull the trigger off and red light turns off, i still get a 1. where does the load come from, can anyone provide me with a wire diagram?? what is the load exactly I'm getting confused. So used to 3 wire switches.
MODERATOR REQUEST:
If you have a new question, please create a new Thread for that question.
Go back one level in the Forum to the "LIVE PLC Questions & Answers" page, and use the Start a New Thread button.
If your question is directly related to an old question, you can link to the old question by copy/pasting the URL of the old thread into your new thread.
Hi all, I have an actuator which I need to control with an AB PLC. Its a 5 core actuator which a motor and limit switch. To extend the arm I...
53
15,922
Does anyone have experience wiring this type of analog pressure transmitter up? It's 4 wires. 3 blacks and 1 green which I assume is earth...
269
Hi everyone, I need some help I new with omron plc. I using plc CP1L. When I do the program it's good and the plc is function as program. But when...
86
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
979
What's everyone use for I/O drawings on new installs. I am trying AutoCad Electrical, but can't download it due to a MS Office application running...
1,315
