Inductive proximity sensor interfacing
The pulse frequency is about 100-150 ppm, i am using a sensor from some surplus equipment to retrofit a machine in our shop.What I would like to do is replace the limit switches which trigger some pneumatic solenoid valves, with a PLC controlled system to increase the precision of operation. We don't have much money to spend on R&D so I am trying to use what we have on hand
Hi Milldrone,
Actually, I would like to use the prox sensor to count the links on a iron conveyor chain and then use that data to fire the pneumatic solenoid valve after the count reach a predetermined set point.
xilog,
My previous post was aimed at narcilla
A 1 watt 20K ohms resistor should work nicely. If a 1 watt is hard to come by two 10 K 1/2 watt in series will work and spread the heat out over a larger area. Keeping Roy's and Okie's suggestions in mind
If you have doubts about how much damage 1 or two watts of heat can do consider this. I use a 15 watt soldering iron to connect Amphenol connectors to cables.
I just looked up the Pepperl&Fuchs switch I have used with 120 VAC Modicon input module.
It's leakage current is <= to 1.7 mA just like yours.
I suggest you just hook your switch in series with a spare input and try it. If you find it doesn't turn off add a resistor as Mildrone indicated.
Sensing links on the chain might be tricky, perhaps you could place your switch beside the tail pulley sprocket teeth.
I'm using an Automation Direct SureServo drive, and it has an 'odd' homing routine. Depending on the state of the home sensor when the HOME...
5,660
We have an old piece of equipment with 5vdc control power. One of the components is a 3-wire NPN shielded 12mm cylindrical inductive prox. I have...
2,956
Hi everybody I use Telemecanique XS1M30MA230 inductive proximity switch in one of my application. It is attached to a moving body. It is working...
5,453
Hello All; I am wondering if anyone has ever come across an inductive prox (preferably cylindrical style) where the sensing face lights up to...
2,128
Dear All, I am using PNP 3-wire DC 24V Inductive Proximity switch and now I need 2-wire DC 24V Inductive Proximity switch. I doubt whether it...
7,272
