Micrologix to pv 1000 w/controlnet
tjoneill
Jul 2007
Michigan
66
Hello again all,
I have a micrologix 1500 that I would like to add a Panelview 1000 2711-T10C15 too ( The Panelview is just an old one we have sitting around). Now, if I use the RS232 port on the PV using the 2711-NC21 cable to connect to the processor, does it matter what protocol the pv is? Is this possible? If so, is their anything else I should need to know?
Thanks again.
The RS232 port on your PV is for uploading/downloading it's program or it can to set for printer use. It cannot be used for communication with your PLC.
The ML1500 does not support Controlnet.
The Comm's cable is a RS232 operating cable Panelview to Micrologix & AIC+. It uses the RS232 port on the Panelview, thats why I thought it would work.
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
165
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,277
Looking at a Micrologix 1000 1761-L32AWA, I tried to connect using the 1761-CBL-PM02 through a Serial to USB converter (This setup was used...
1,000
Hello All I am trying to convert a ML1000 program for use in a ML1400. I didn't create the original program & documentation is non existent...
4,435
Hey Folks, I have a customer with an older machine that is controlled with a MicroLogix 1000. The machine just quit working. The power light is...
22
10,657
