Compactlogix L32E
What have you tried?
Used a USB to RS23 conector. No response
Do you have RSLinx?
Yep. I cant assign an IP
Do you have a BOOTP server to assign IP?
yep but IP is not asigned
Is this new unit or trying to connect to a existing unit?
If it's already been programmed then BOOTP may be disabled.
If new make sure the computer and plc are directly connected, its best to do without a router or switch unless you know for sure there is no DHCP server running. Make sure you disable antivirus, run BOOTP tool with administrative privilege. You should see the MAC address in list show up.
If you do not know the IP you'll have to use a packet sniffer like Wireshark to possibly see the broadcast IP when the controller boots.
Did it not show up in RSLinx when you tried with RS-232? And is the error light on after the processor has powered up? I guess it would also be good to ask if you're familiar with Allen Bradley products, or is this your first experience using them?
Hello . Info: Panelview plus 400 2711P-K4M20D Compactlogix 1769-l32E i make a program in RSlogix 5000 and Factorytalk view for...
1,804
Hello again. I need to flash a CompactLogix L32E from firmware ver15 to 16. It has several Panelview Plus's Series D Rev A, connected via...
2,792
Hello. I am trying to establish communication between CompactLogix 1769-L32E and CompactLogix 1768-L43 using serial port but with DeviceNet (and...
2,762
Respected sir/madam I have CompactLogix L32E And I want to data log into logic . is any module or card require to it. request you guid me and if...
1,395
A new member of our Forum community, maheshbhaiya, posted this as PMs and a resurrected thread, so I'm going to give it a push in the right...
2,090
