mehkocak Member M Join Date Jan 2005 Posts 58 Oct 11, 2005 #1 how can I find some detail informtaion about SCL programming language in S7 and one more thing is it possible to see the program in other languages ( STL,LAD )of plc programming.
RheinhardtP Lifetime Supporting Member + Moderator Join Date Oct 2004 Location Perth Posts 562 Oct 11, 2005 #2 Step 7 Help I have found the Step 7 Help list is quite informative even when learning. When you view a command you maybe dont understand F1 will explain basic operation of command. There propably will be tons of books on the subject Try this link, there is loads of stuff http://www.google.co.za/search?hl=af&q=SCL+book+PLC+language&meta= Using Step 7 you can switch between SCL, Function block and ladder under the Drop Down menu under the view TAB . If you understand ladder you can convert commands to SCL, and visa versa. Not all SCL command s can be changed to LAD. Regards Rheinhardt Last edited: Oct 11, 2005
danpantea Member D Join Date Sep 2005 Location Pago Pago Posts 76 Oct 11, 2005 #3 It helps if you know Pascal! IT DOESN'T CONVERT WELL IN STL!!!!!!! PLEASE IF YOU OPEN IT IN STL FOR REFERENCE DON'T SAVE.
