Boyko Member Join Date Oct 2005 Location -- Posts 26 Jan 31, 2006 #1 Hi. What's the "LED register" in the EDIT>>SETUP menu for? I couldn't find an explanation into the manual. Regards
Pierre Lifetime Supporting Member Join Date Apr 2002 Location Montreal Posts 1,669 Jan 31, 2006 #2 Boyko said: Hi. What's the "LED register" in the EDIT>>SETUP menu for? I couldn't find an explanation into the manual. Regards Click to expand... Its to make use of the 2 LED in the front. You can have them be RED or GREEN and Blink to a certain frequency by writing a value to the selected register.
Boyko Member OP Join Date Oct 2005 Location -- Posts 26 Jan 31, 2006 #3 What value do I need to type to blink the upper LED for ex.?
IO_Rack Member Join Date Aug 2003 Location Upper Chesapeake Bay Posts 238 Jan 31, 2006 #4 In the register that you choose, bit 0 is the red LED and bit 1 is the green LED. Example: If you choose register H10 in NT2 ST, then you manipulate outputs H10.00 and H10.01 in the PLC. Make them blink or whatever you want.
