OT: Metered Powder Output Sense
Aabeck
Feb 2013
Detroit
1,860
I am working on an experimental system for a new chemical a supplier of a client of mine has invented and my customer is going to be their Guinea Pig.
The chemical needs replenished based on Amp/Hours applied by 2 rectifier power supplies. But the replenish is not a chemical metering pump I can control the pulses and check for flow out of the pump - it will be a dry powder added 148 grams each replenish.
The control will be run an auger motor for x.xx seconds to get the precise amount of powder. OK with me so far.
My issue is there isn't any monitoring of output to ensure the powder is actually dropping into the tank. The amount is about 5 ounces, so I was thinking drop the powder into a scoop or trough that trips a switch at over 4 ounces, then after the auger stops dump the trough. Not 4 ounces means drive failure, powder bin empty, fuse blown, etc. - set an alarm.
Has anyone ever used a monitoring system similar to this and know who has them? Or am I going to have to design one myself? I don't want to just run it and at the end of the day find out the system wasn't working.
Yeah most powder mixing systems I have seen they just assume the powder is getting through or have been adding the powder manually in one tank and using a transfer pump to move it over to the distribution system tank.
I do like where your head is at though, weighing it seems like a logical solution.
I set up a recipe and control system at a factory that mixed and packaged dry baking mixes, and they used weight as well. I think that's the easiest & most accurate method when dealing with powders.
Doug,
That looks like a nice dispenser, but the chemical maker is supplying the dispenser for their powder. And for measuring they hand place the cup on a scale.
Is the powder going into a liquid? Is there anyway to instead makeup a higher concentration liquid manually and use that as feedstock to the process?
Shooter,
That was my question to the chemical engineer, I could scoop the exact amount and make sure the scoop cycled by proxy or encoder, but he said it's the dispensing system they use - and it's a lock.
g,
This customer does have a lot of "day tanks' for other lines they fill in the morning and meter out as needed, but for some reason that is not an option with this powder per the chemical engineer.
So they already have the dispenser system that they say you must use? You are just trying to devise a way to verify?
We had a system that we developed that would meter dry powder into a liquid. The system never worked correctly as the dry powder was not very repeatable per rotation of a n auger. Also, the power would stick to the funnel/shoot leading into the tank due to liquid splashing out etc. Tons of time was wasted on this effort until we finally replaced it with a "concentrate" tank that had an overly strong mixture. This worked much much better.
JaxGTO:
That may be possible, but 50# of powder and the weight of the assembly, then trying to make sure it lowers at least 140 grams might be asking for a lot, Maybe?
g.,
Found the reason they say they can't have a day-tank and meter in concentrate - they can't add any more fluid to the tank as it would need to be drained off and this waste would need heavily treated to be able to dispose of, at a prohibitive cost. And the reasons you stated are the reasons I want to make sure the minimum quantity of powder is dispensed every call - if there is more it will be OK to have a stronger solution, just a waste of powder.
...but 50# of powder and the weight of the assembly, then trying to make sure it lowers at least 140 grams might be asking for a lot...
140 grams = .3 pounds.
I could go 2 decimal places with 100 pound load cells if I knew there wasn't any vibration during measurement. If it's noisy, then I need time to take several readings and average.
keithkyil,
That does sound like it would work, I'll pass that suggestion on tomorrow. And in the long run it might be less expensive than making a trough to catch, weigh and dump.
Hi all, I was assigned to develop an architecture for the system in which i have to calculate the amount of powder that will be inleted in to a...
1,729
We have a photo sensor to monitor the flow of starch but coz of the dusty environment the sensor is generating teh fales alarm. Putting the...
37
7,712
My customer has a powder tablet pressing machine from a company not longer in business. I was asked to replace the feedback from the load cell...
2,089
Can any one tell me which is the best On Line measurement system for Milk Powder Moisture measurement. At the moment I have 2 in mind : 1) MM710...
3,516
Looking for some hands on user's experience setting steel bolts into steel using powder actuated gun. The PLAN 1. Set chiller into place and...
25
5,452
