OT: Metered Powder Output Sense
Typical is 5000 counts. For a 100 pound scale, that's +/- .02 pounds, 9 grams. You start working on the little things to get better than that. Up to 40,000 counts is possible, but probably not realistic in an industrial setting. With proper design, I expect I could get 10,000 counts in production.
Just a note.
Most bread making industry use weight measurement systems.
Even plastic bottles
What I ended up doing is making a self dumping tub out of a small plastic parts tray and a pneumatic cylinder. Then I mounted the assembly on top of a 5 pound scale with an analog output, mounted so it dumps over the edge of the scale.
The PLC records the empty weight after each dump for tare and the weight while filling, stops the auger when the right amount and dumps the tray into the mixing tank below the scale.
If the solution gets low concentration the operator can adjust the powder weight on the HMI, within reasonable limits.
Also, the powder feels and acts exactly like powdered sugar used in baking and cake icing, except one cup of the stuff weighs almost 3 pounds/1.3 kg and it is a very dark gray color, as it's powdered copper.
Are you aware the link in you signature leads to a *** chat site?
I deleted it.
I retired and no longer have the domain, and haven't logged in here in a while.
But when I clicked it to see what was censored I got a Buy This Domain page, not any chat.
II retired and no longer have the domain, and haven't logged in here in a while.
That explains why I haven't been able to get you on the phone to come & update a couple lines you worked on here. Sorry to hear that. Do you have a suggestion of someone in the area with your level of knowledge?
The number of people who announced they retired, just on this forum, is quite surprising. I wonder if there is enough talent out there to fill these spots as quick as they're vacated.
Hi all, I was assigned to develop an architecture for the system in which i have to calculate the amount of powder that will be inleted in to a...
1,740
We have a photo sensor to monitor the flow of starch but coz of the dusty environment the sensor is generating teh fales alarm. Putting the...
37
7,735
My customer has a powder tablet pressing machine from a company not longer in business. I was asked to replace the feedback from the load cell...
2,093
Can any one tell me which is the best On Line measurement system for Milk Powder Moisture measurement. At the moment I have 2 in mind : 1) MM710...
3,519
Looking for some hands on user's experience setting steel bolts into steel using powder actuated gun. The PLAN 1. Set chiller into place and...
25
5,467
