TWControls,
Technically and theroetically, whether or not to ground one or both ends of a cable depends on the frequency of the currents. Low frequencies = ground one end. Higher frequencies = ground both ends.
Grounding both ends of a cable shield can cause problems only if the facility grounding system is not up to par. If there are parts of the plant that have poor equipment grounding conductors, then grounding both ends of a shield can create the missing ground (that should have been achieved by normal grounding methods). That is the main reason that traditionally it has been considered bad practice.
For over 100 years, the US National Electric Code promoted poor building grounding with the idea that an earth connection could be achieved with a wire bolted to a water pipe, or a single rod driven into any type of soil. This simply is not true and caused many problems with things like how to ground cable shielding. Now that many local electrical Code Authorities are adopting the Ufer Grounding System, those problems will almost disappear.
