5069-OB16 LA Power From E-Stop
DaDaDadeo
Feb 2018
New York State
92
Using a ControlLogix baseline drawing, the 1769-OB32 have 2 separate power sources for 16 outputs each. Converting the drawing to a 5380 system, the specification sheet shows a single LA power input for the 5069-OB16. However, I am not sure whether LA Power supply can be interlocked through an E-Stop. It looks as though the card will fault if the LA power is cut when the E-Stop is pressed. If so, the LA power must be continuous?
I may have to use an array of slim relays for separate power feeds.
Hello, I have a laying out a system that will have a CompactLogix rack and I had a question on the power for the inputs and outputs. I was...
392
Hello all, I've ran into a problem where we are trying to give a solenoid 2 inputs and this is causing a problem on the output card. as you...
1,247
AOP file download for 5069-OB16 V3.001, and, AOP file download for 5094-IB16 V2.001 on a client program workstation they show the yellow...
1,781
Hi All, I have a 5069-OB16 series B, v3.11 output card. It is just flashing red. Any information or help? Regards
6,753
Hi All Can anyone help me with EDS files for 5069-IB16 & OB16. Thanks you!
2,017
