DaDaDadeo
Using a ControlLogix baseline drawing, the 1769-OB32 have 2 separate power sources for 16 outputs each. Converting the drawing to a 5380 system, the specification sheet shows a single LA power input for the 5069-OB16. However, I am not sure whether LA Power supply can be interlocked through an E-Stop. It looks as though the card will fault if the LA power is cut when the E-Stop is pressed. If so, the LA power must be continuous?
I may have to use an array of slim relays for separate power feeds.
