server redundancy
Charbel
Jan 2012
Beirut
307
dear,
i want your advice if possible on the below
i have one PLC cabinet with dual redundant PLC located in substation 1 where an operator will be there. Another operator will be located in substation 2. substation 1 is connected to substation 2 using dual redundant fiber optic cables.
network design can be in one of the 2 different options:
1- Substation 1 will be housing two redundant SCADA servers, one historian server, operator workstation and engineering workstation.
Substation 2 will be housing client to the SCADA servers located in substation 1
2- Substation 1 will be housing one SCADA server, operator workstation and engineering workstatiaon
Substation 2 will be housing one SCADA server (redundant to the server located in substation 1) and one client.
The 2 redundant servers in the second option will also have an integrated historian server.
which option is better? are any standard which can confirm the selection like TIA-942?
Thanks for your advice!!
Charbel
Use ignition as your scada and put a sever at each location. Assuming you have not chosen a scada option
Mohsin
:unsure: This post is so great and nice o_O
dear,
thank you for your reply :), is the option of having one SCADA server in each location following a certain standard like TIA-942?
thanks a lot!
charbel
So, after adding a second PC, purchasing another server license and setting up to function as a redundant server for FTV SE, I think I've...
2,176
Hi Friends, I'm working on a Redundancy discrepancy on our VijeoCitect SCADA, The Primary can not take over when the Secondary Server goes down...
1,289
I have a Cimplicity Redundant Application. But when I start Secondary Server from Primary Server, it gives an error' unable to start the project...
1,882
I am working on commissioning 4 stations. I am using Allen Bradley software and I am using Client/Server Arch. Each station has its own controller...
1,681
Hi, I am getting an error in hmi server redundancy. I have SERVER A,SERVER B,SERVER D. total 3 servers Server A and Server B are redundant hmi...
3,825
