Panelview 300 Micro Error Code 40
alexbeatle
Feb 2010
San Francisco
188
Hello, everyone.
Panelview 300 Micro has recently stopped working. It shows error 40 at the startup. According to the manual this error means there is "no executable code to run after boot".
After doing a little bit of research I found that it could very well be due to corrupted project.
Has anybody experienced this problem?
Thanks,
Alex
No, I haven't ( Power supply, surge protection?). Can you connect to it and download it's program? Hopefully you had a backup.
Yes I have. RSLinx doesn't detect it. Cannot connect to download\upload the program.
Have you connected to it before?
What is the complete catalog number of your PV?
What driver are you using to connect to it?
That sounds like time to call your local AB rep.
Thank you, Mickey
Yes, I have connected it many times before. The machine was working fine for several years. But a few days ago, I was passing by it and saw the error code on the PanelView.
It's a PV300 Micro 2711-M3A18L1 - DF1 protocol.
Since it doesn't boot past the error code, RSLinx cannot autodetect it.
Since the error discription is - "no executable code to run after boot", could the firmware be re-uploaded? Perhaps there is a service mode?
S
Again, it sounds like it's time to call your local AB rep.
Yeah and for this error the price for repair this is 400$ &+ my probleme with ERROR 40 is when i download firmware in panel, my computer having a problem and reboot... but download is not finish..... PanelView 300 say to me error 40 and not boot..!
Service Allen Bradley say to me is 400$ and over for reprogramming it! humm
Pode ser tarde, mas resolvi esse problema fazendo download do firmware.
It may be late, but solved this problem by downloading the firmware.
Is this the clock battery flat? Does anyone know how to remove the back of the PV 300 micro. Is it possible to replace this battery. AB says it's...
1,184
I have an opportunity to get some more experience replacing an old Panelview 300 Micro. I'd like to hear any advice you have about it. I suspect...
3,315
I lost the manual for this machine built in 2003 and need to put it back together. I have the Micrologix 1200 and PanelView 300 Micro programs...
1,787
I am tying to download application software to a fresh out of the box PV 300 Micro. The first hitch is a prompt that I am running v4.1xx RSLinx...
1,153
I went on a service call yesterday for a Micrologix 1500. An output wasn't activating and they wanted to know what was hanging it up. It was a...
2,819
