Sinamics S120 Drives
plcengineer
Jan 2004
USA
176
We are installing new S120 drives on a R&D machine.. we will have a master drive with multiple slaves.. The slaves will follow the master line speed and then the ratio to the master. The rolls are different roll diameters and have different gearing.. Does the S120 have a setting to adjust gearing? Or should I do the following.. Set Master Line Actual Roll Speed to xx fpm and make all other surface area speeds match.. Then, I could use the mult blocks to adjust my line speed to get the proper roll speed, then my ratio could adjust on top of that..
As of now, we have the master drive speed output feeding the slaves and everything controls well.. However, our speeds are not correct because of the gearing-roll diameter differences.. Just looking for the best way to compensate for this in the S120..
Thanks,
Easy. Just adjust p2000 to the proper value. So let’s say your desired surface speed is 100 ypm , but the actual is 120.
100/120 = .833
Take .833 x p2000
Then adjust p2000 to your answer
Hello to all, I have a STEP 7 project (v5.6) with S7-400F CPU and Sinamics S120 drives with CU320x2PN (ord. nr. 6SL3 040-1MA01-0Axx). I need to...
963
Kindly, can we install new Siemens Sinamics S120 motor modules and new 1FK7 servomotors, in place of old types ? Will the old motion control...
1,136
We have a couple of S120 drives which are rack pinion system,which moves forward and back ward (linear motion only) . The drive shows Fault 7900 3...
19
4,348
Hi all, I'm working on migrating some old Sinamics S120 drive units currently integrated in Step 7 5.6/WinCC Flexible 2008 RT to TIA Portal V14...
3,425
I have a master slave setup for speed control.. I used the encoder speed unsmoothed from the master to the slaves.. It is a speed control...
1,479
