Paul B
I'll keep this as brief as possible, but it is a long story. I've been programming 90-30's since the late 90's. Haven't used them much lately but have an old customer needing some work done.
I changed the CPU331 to a CPU350 so I can use Proficy Machine Edition v.8.50 (which is not the latest but what I have). I relocated all the I/O modules to open up slot 2 for a CMM321 Ethernet interface module. My goal is to throw up a wireless access point and be online to the CPU without having to use a serial cable.
Found CMM321's for around $125 on eBay, the AAUI transceiver is around $20. After much reading I decided to invest another $20 in a 10mb hub because it is reported the older CMM321 with AAUI transceiver's don't talk well with modern switches.
I have this working right now with the wireless access point so I can move around the room and stay online. Yes it has to have the 10mb hub in between the transceiver and the wireless access point, it will not work without the 10mb hub.
Here's my issues:
Unable to go online with Proficy Machine Edition 8.5 via Ethernet on Windows 7 64-bit. I can go online serially with this software on this OS. At first I thought this was my problem with the hardware.
I took an old laptop running Windows XP and LM90 and was able to go online to the 90-30 PLC using LM90 Ethernet, so that proved the hardware. Turns out this old Windows XP laptop has version 8.0 of Proficy Machine Edition and I can get online via Ethernet with version 8.0.
On this old laptop I can shut it down and stick in a Windows 7 64-bit drive running Proficy v8.5 and cannot go online via Ethernet. This echoes my testing on other computers (Virtual Machines) also running Windows 7 64-bit and Proficy v8.5.
I know how to roll my project back to Proficy v8.0 by uploading from the PLC and importing the variables, but of course I cannot retain the rung comments. There are a LOT of rung comments so this is not desirable.
I'd like to be able to go online via Ethernet to the 90-30 CMM321 module using Proficy Machine Edition v 8.5 on 64-bit Windows 7. Any suggestions are appreciated.
Thanks,
Paul Blanchard
Here's my issues:
Thanks,
Paul Blanchard
