Fatek PLC online via Ethernet module CBEH0A
yasir_66
Oct 2015
Pakistan
Dear All,
Anybody can help me in communication between Fatek 20MAR2 & CBEH0A. The jumpers setting are JP1 is on left two pins (No password protected) & JP3 is on right two pins (forced boot operation mode). I tried with removing both jumpers but problem still same. The Ethernet cable i used is type b T568. Fatek Ethernet module config software detecting module successfully (shown in attached pic) but on online PLC via ethernet cable its showing connection failed.
please help
thanks in advance
Hi everyone, i hope you are doing well i am using fbs 2lc module , i have calibrated the weight by calibrated weight but my value is not...
90
Hi; I have Laptop Lenovo Thinkpad (W10) which don't have built-in Bluetooth. I have a PLC having Bluetooth communication device. I wanted to...
138
Hi everyone I am using Winproladder software for programming FATEK FBs PLCs and in programming, we often use Timers for activation of the...
595
Hi friends, I have a problem. I want to read ASCII data over rs232 standard port. How can I do the reading process? FATEK FBs-CB25 -> port1...
752
Dear all, I want to use the interrupt service routine in FATEK PLC using WinproLadder Software. I had configured the interrupt in software as...
17
1,589
