Faizan_Automata
Dear all,
I want to use the interrupt service routine in FATEK PLC using WinproLadder Software. I had configured the interrupt in software as External Interrupt attached to input contact "X0" and it will be triggered when rising postive edge is detected. After programming, the interrupt routine works well but the standard timers attached inside the sub routine does not get enable and not even starts running.
I think the timers does not get more than one scan time as ISR returns to main program immediately at the end of RTI instruction or may be it is a different issue. Need your help in how I can manage to run timers inside the interrupt ISR Routine in sub program part of WinproLadder?
