Cheapest way to get a 4-20mA input value into a Red Lion HMI
AutomationTechBrian
Jul 2013
St. Cloud, MN
671
I've been talking to a customer about creating an HMI screen that tracks machine productivity. The only external input would be one 4-20mA analog signal. Cost is a little bit of a challenge in selling the project, so I'm trying to figure out the cheapest way to get a 4-20mA value into the Red Lion HMI (probably G3). I was thinking an Automation Direct PLC and maybe bringing it in on a serial port. (I'm assuming the drivers are available). Seems like overkill, but can't think of a cheaper way to do it. Any thoughts?
This will be in a stand-alone enclosure, with a 24vdc power supply for the HMI. 110vac is coming in, along with one analog cable. That's it. Later on, they would add an ethernet cable for using the web server feature.
The Red Lion Graphite HMI's have modules you can add to the HMI. I dont know what they cost.
Also the Automation Direct Click PLC would be the cheapest PLC that I have worked with. A unit with 2 AI and Ethernet is less than $200. Software is free and they are pretty easy to work with.
The graphite do cost more. Im.thinking cheapest is either the click.or maybe a modbus phoenixcontact 2ai block might be close to click
Does it have to be on a HMI screen, a LED Analogue reader would be pence in comparison and in effect, do the same job.
$150 USD will get you a Siemens Logo!8 with 4 AI (0-10V), built in ethernet port and a built in screen.
use a 500Ohm resistor to convert your 4-20mA to 2-10V signal.
Can be programmed in linux too, so if this is all you are doing, you could save a packet in windows licences.
I would use a click with a separate analog input module. The analog input will be the part of the system that is most likely to be damaged if there is a problem, so using a separate card makes it easier to maintain.
I would go for the ethernet click so that once networked, you will be able to access it or the HMI remotely.
I think you are still under $200 with that set up and the Click seems to be pretty rugged.
I have used a number of the GMUIN400 Universal Input Modules. We use to get them for just under $400.00, but the price keeps climbing. Last one I bought a couple months ago was $464.00. I do like them tho, but they are more expensive than the A-B 5069-IY4 Modules now.
Look for a low cost temperature controller with Modbus. I've seen some under $50.
You also might want to look for a thermostat like device for building automation with 4-20ma and Modbus.
They seem like nice kit for simple projects, but how about the required software, is that a free download, or paid? If the latter, do you know how much it is (ballpark figure)?
Thanks for all of the replies. I think the Click PLC makes a lot of sense. I'll just use one with the integrated analog inputs... it's only $125. I'm looking at the DEMO software for the C-More EA9 HMIs as well. I think I'll lose the project if I push the Red Lion. I have a little learning curve with the C-More, but I'd like to get familiar with it anyway, and this is the slower time of the year.
I'll be posting a question about creating a couple of visual timers in the C-More to track up-time and down-time.
..that you know of, other than the 1783-ETAP A? I am trying to setup a device-level ring testing setup environment for training that I may need...
1,485
I have an application that needs 20 inputs and 20 outputs with only 10 XNOR and 10 NAND blocks. I could do it with relays, but this could end up...
5,205
Hello, What would be the cheapest PLC running codesys I would be able to get my hands on? I like to expand my mind and I started out as an AB guy...
30
13,619
I want to fill a hole in my skillset by picking up AB PLC programming. Although I'm at a very advanced level with GE PLCs (I mean GE-IP, no I...
3,365
I almost have a complete, basic setup for a shop/learning fixture. I've got a used CPU317-2 DP, a G120C, and some purple hose. I'd like to add...
20
5,425
