What is the cheapest device-level ring supervisor...
AlfredoQuintero
Feb 2015
Yokohama
1,551
..that you know of, other than the 1783-ETAP A?
I am trying to setup a device-level ring testing setup environment for training that I may need to loan to customers, but I do not want to loan my very expensive DLR supervisors that I use for many other things most of the time.
1783-ETAP A is plentifully available in eBay, but it supports a very old version of the DLR object and Rockwell has not updated firmware version from 2.02 and some conformance test cases fail due to the 1783-ETAP, not the device under test.
Some new generation devices like the 5069-AENTR support DLR supervisor and would do the job nicely. But this module without IO commands over US$ 2K in eBay. I am looking for something 25% of that value. I do not care if it scratched or dented, as long as it works. Any ideas from the Rockwell world experts would be very much appreciated.
List of supervisor capable devices is not very long:
1756-ENxTR, 5370/5380/5480 controllers, 5069/5094 adapters, ETAP and some Stratix switches.
Maybe I missed some…
I have an application that needs 20 inputs and 20 outputs with only 10 XNOR and 10 NAND blocks. I could do it with relays, but this could end up...
5,172
Hello, What would be the cheapest PLC running codesys I would be able to get my hands on? I like to expand my mind and I started out as an AB guy...
30
13,485
I want to fill a hole in my skillset by picking up AB PLC programming. Although I'm at a very advanced level with GE PLCs (I mean GE-IP, no I...
3,340
I almost have a complete, basic setup for a shop/learning fixture. I've got a used CPU317-2 DP, a G120C, and some purple hose. I'd like to add...
20
5,383
What are some reliable but low cost options for an ethernetIP based remote IO you can get ? I need a few to communicate with a Rockwell...
38
15,104
