Cheapest Codesys PLC
I have several Beckhoff CX at home which I bought on ebay fairly cheap ($200 to $400?), since I was using it a lot at work. One is a CX2100, their top DIN-rail processor at the time. At least one has the NC license, which should support hopes to turn my milling machine into a servo-drive CNC. I have a lot of time since my company abandoned my city and laid most off, including me, once I finish home projects backlog, then looking at consulting since all interviews have gone nowhere (over-qualified and/or age discrimination). As mentioned, you can get into Beckhoff (CodeSys based) for free, and using their hardware emulator is no different than real hardware, unless you want to see lamps flash and things move.
I think what they mean is that they are cheap and don't want to pay for experience and talent. At least that is what I always tell myself when I hear that line.
What kind of cheap CoDeSys PLCs or smart relays are available these days? I'd like to have something like...
5,619
..that you know of, other than the 1783-ETAP A? I am trying to setup a device-level ring testing setup environment for training that I may need...
1,481
I have an application that needs 20 inputs and 20 outputs with only 10 XNOR and 10 NAND blocks. I could do it with relays, but this could end up...
5,171
I want to fill a hole in my skillset by picking up AB PLC programming. Although I'm at a very advanced level with GE PLCs (I mean GE-IP, no I...
3,339
I almost have a complete, basic setup for a shop/learning fixture. I've got a used CPU317-2 DP, a G120C, and some purple hose. I'd like to add...
20
5,383
