Cheapest CoDeSys PLC/smart relay?
ask his in codesys forum, or look at list of companies using codesys.
www,codesys.com and yes i use a lot of codesys, wago but that is too expensive for you.
yes i do like this devilbiss, simple but it works.
hhave a look at arduino, very cheap and open source.
Hello, What would be the cheapest PLC running codesys I would be able to get my hands on? I like to expand my mind and I started out as an AB guy...
30
13,522
..that you know of, other than the 1783-ETAP A? I am trying to setup a device-level ring testing setup environment for training that I may need...
1,482
I have an application that needs 20 inputs and 20 outputs with only 10 XNOR and 10 NAND blocks. I could do it with relays, but this could end up...
5,179
I want to fill a hole in my skillset by picking up AB PLC programming. Although I'm at a very advanced level with GE PLCs (I mean GE-IP, no I...
3,343
I almost have a complete, basic setup for a shop/learning fixture. I've got a used CPU317-2 DP, a G120C, and some purple hose. I'd like to add...
20
5,389
