RSview32- Save Data through VBA in Excel To generate Reports - RSview32- Guardar Dato
garcgc
Jan 2018
Montelibano
Good friends, I'm new to the forum, I'm working with RSview32, someone can help me how to make a macro in VBA, to save some data in Excel. to generate some reports. ------
Buenas compañeros, soy nuevo en el foro, estoy trabajando con RSview32, alguien me puede ayudar como realizar una macro en VBA, para guardar unos datos en Excel. para generar unos reportes.
Since you haven't replied, I will tell you this.
you MUST do the following.
What version of RSView are you using? VERY important.
is this a runtime package or developer package?
Get with RSView tech support and find out if the version of RSView that you have supports visual basic or visual basic.net. tell them what you are doing.
answer my questions posted earlier and add 25% to the data quantity.
Get all the variable names and addresses from the plc.
get all the data names from RSView32.
if production is critical, you will need another copy of rsview for development and testing.
get a copy of the VB program required and install it.
Write the VB program.
this is NOT a 20 minute fix.
for the experienced vb programmer and rsview user, this is a 3 week minimum job!
the first report that we did took 5 weeks and a week debug onsite.
if the data required is for 7 am to midnight for example, add an additional 2 weeks.
depending on the amount of data, the report will take 30 minutes to 4 hours.
we took data for 60,000 produced items, 20 hours of production data. the average report took 2 hours.
We contracted the OEM who built our equipment to write the program.
I did have to modify a good bit of code for him.
regards,
james
Hi Garcgc:
My approach is to use a report generator. It´s an Excel add in.
For several years I´ve been using XLReporter from www.sytech.com, additionally you have to buy an OPC server , we use FTalk OPC Gateway as our OPC server.
You can learn the whole thing the same day.
I sent you the answers to the questions
Hi James,
What are you trying to do?
I am trying to make a report in excel, that I keep weight data.
Save some data - ok. How much data?
approximately 30 weighing, seals, operator name, weighing dates and times.
what kind of data?
decimals, data and time, integers, text.
How often?
every time the weight batch is made.
When do you want the reports to be generated?
Welcome to the forum.
what kind of data?
How often?
As I said in my earlier post.
What version of rsview?
what os is the program running on?
is this a runtime package or a development package?
if it is a runtime package, do you have the same version of development package?
I had to hire someone to do the programming for the company.
you have to get these answers to start.
if you have the development software and your customer has the runtime, the version of software does matter.
i'm sorry, I have given you all the information I have, i'm not a vb programmer.
YOU MUST make backup copies of the application first!
this will save you a lot of grief if things don't work out.
james
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
407
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,928
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
610
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,453
I have converted RSV32 to FTVSE Distributed. pretty straightforward... I cant seem to figure out how or find any documentation to migrate RSV32...
2,316
