RSView32 to FTVSE Station
Hoozie
Oct 2011
Ohio
I have converted RSV32 to FTVSE Distributed. pretty straightforward...
I cant seem to figure out how or find any documentation to migrate RSV32 to FTVSE Station. Is there a quick way to do this or just create a new Station application and start importing all of the Distributed application items?
To clarify, there are two application types called "Station". There is a "Network Station" and a "Local Station" (usually called Local). I'm guessing you are referring to the Local Station type.
For a Network Station application you can create a new application or use an existing application. Create a new HMI Server and select Import and then choose RSView32. You perform the import as part of adding the HMI server.
For a Local Station type application an HMI Server is created by default. It cannot be deleted. Nor can you add a second HMI server. So, you cannot import into an existing local application. Instead, you must create a new application, and as part of creating the application, you import the RSView32 application into that new FT Local Station application.
In FT Studio on the tab for New there is an Import button. Click on that and you will be able to specify that you are importing an RSView32 application.
OG
Thanks OG. Appreciate your help
I tried that but probably did not see the import button when creating a Local Station. I'll try that tomorrow.
Yeah... :sick:
In 25 years of this I bet I've spent a months worth of time looking for, or overlooking, a button or checkbox. Whether its Rockwell, Siemens, Autodesk....
Thanks again OG. I have my SE Local Station client running now. Spent 8 hours this week trying do something that takes 15 minutes!
I'm working on a conversion project from RSVIEW32 --> FTViewSE 7.0. A lot of Macros have an "Invoke" command - what does that do? I'm not...
2,344
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
375
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,913
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
599
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,435
