Controllogix Controller Workload
jmaty23
Mar 2009
New York
49
Is there a point to where a Controllogix processor receives too many requests for data from external/remote Ethernet devices that it degrades the performance of the processor itself?
Not quite "degrades the performance of the processor...", the processor will still be running at clock speed.
It will just affect the scan time, which "degrades the performance of the application..." I'm sure that's what you meant, though.
That is assuming, of course, that the "System Overhead Time Slice" is set high enough to handle the incoming data requests, and the resultant sending of same.
In my experience, the communication functions will suffer before the processing of logic is impacted. We’ve been known to set the proportion of time executing logic as low as 15% without impacting processing speed, thereby allowing much more time for comms and other internal housekeeping.
I suggest experimenting with that setting to determine what works best for you.
Since V16, you can set the SOTS extremely high, to accommodate for comms "splurges", with the check-box set to resume scanning logic as soon as it can. This is the best setting under most circumstances - I have seen and used SOTS 80 to 90% also.
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
382
Hi All, Looking to get some direction on how to get data from a piece of equipment that has RS-232 communication (1-way) to a 1756-L73...
336
The site I am working with has a site-wide DeltaV SCADA system. I am working on a package that all falls under a single ControlLogix controller...
1,869
Good Morning , I have a bank of Kinetix 6000 Drives that I'm getting faults on. I took notice in my ControlLogix , Controller Tags for the...
3,719
Hey people, Just wondering if anyone has run across this issue and if there is a solution. Here is the situation. I have a program that has a...
1,934
