Unable to control vlt2800 via profibus using s7300
antonydias
Dec 2007
Jeddah
I am unable to control an Danfoss inverter VLT 2800 via profibus using Siemens S7300 PLC.
Communication between PLC & VLT 2800 is established using Type PPO 3(I/O address 256).
I programmed as follows
L W#16#047E
T PQW 256
L W#16#4000
T PQW 258
But the inverter is not getting start commands.
Kindly guide
Dear Sir,
I want to know How I make "configuration telegram system" in VLT 2800 with S7 314c 2PN/DP
We complete Hardware configuration by GSD
But could n't complete LAD(PIW718 and PQW 718) as well as Parameter setup in VLT2800.
Kindly assist me regarding my issue as urgent basis
Dear sir,
As per your request, I have attached here the print screen of HW and LAd design.
I hope you will check and advise me, how I progress my learning about VLT2800 with S7 300.
I don't understand the program
If you want my sample program more undersigning I will send you.
For your kind information program file size is more than 5MB so it need send through email.
Hello, I need to restore runtime application in Application Manager (Rockwell) and I have a problem during I restore runtime. Application Manager...
1,353
Hello Members, I hope you are all doing well. Coming back to my issue , I had recently converted an backup which was mae for FTV 8.10 to the FTV...
1,584
Hi, I'm trying to send write (MWX) commands from DL06 for frequency and start/stop control of a motor connected to a GS1 Drive. The GS1 Drive...
1,527
Hello everyone, I am currently working on a project for Factory talk view 6.10 SE. When I open the program, there are several error messages...
22,947
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
231
