cskaggs2
-I have a SLC 5/02 that loses its program each time we cycle power off. We have replaced the battery, but this does not resolve the issue. Any ideas? I am tired of reloading programs.
-I am also having an issue with this SLC PLC not having the correct values for some machine settings (3 voltage settings for tension control). The SLC 5/02 is interfaced to a PLC-5. The PLC-5 is supposed to send the settings to the SLC 5/02. I can see the correct recipe settings on the HMI, but the SLC 5/02 has the wrong settings (and the drives controlled by the SLC output the wrong voltage). This is an intermittent issue and goes away without any explanation.
-With the program loss at power downs and this intermittent issue, I am suspecting a faulty SLC 5/02. I have SLC 5/03 5/04 on the shelf, but I am not sure steps involved in changing. Will I need different cables to interface to the PLC-5?
