To expand on Netvisor's reply:
I hope I get ALL the facts right (and don't forget anything), so I don't get flamed.
An interesting thing you'll see, if you hook up a multimeter; PNP (Sourcing) works like you'd expect. If it's ON, you see (logic high)voltage; OFF - low (logic low) voltage.
NPN (sinking) can be trickier. The circuit blocks CURRENT until it is switched on, so you'll see voltage in the OFF state. In the ON state, the device acts as a current path and you'll see a low voltage.
AK
Ok guys: where did I screw up?
